Originally posted by cardana24
View Post
Yes a blazer/pickup flywheel will work. But that link you gave us shows an external balance flywheel.
I had a chance to work on the jeep for a few hours tonight. I am getting pretty close to being able to pull the engine. All of the acessories are off now, most all of the wiring/vacuum is un hooked, the throttle cables are disconnected, the starter is out, the exhaust is cut off, the tranny is drained. Here are a few pics. When I have a few more hours after work one day I am going to try to yank the engine. I would like to disconnect the tranny before I pull it, do you guys know how hard it is? From looking at it the top bolt closest to the firewall/tunnel will be the only real pain. Any thoughts on this? Anyway here are a few pics, feel free to post thoughts or advice.
**oh yeah, check out the motor mount on the right (pass.) side...it has no rubber above the bolt, I think it is time for some new mounts
But that one according to the Parts America site has the wrong number of teeth.Originally posted by betterthanyou View PostNo. The Camaro wheel was a strange one. It has a very large dish in it. You need the S-10 style flywheel.
**Ok I tried looking up the flywheel for a 1988 FI 2.8 blazer and it calls for a flywheel with 148 teeth...the same amount as my 1985 jeep. So since the blazer was fuel injected I assume this means it was a model that was internally balanced. Is this correct, and will this bolt up to and fit my jeep with no modifications. Also I have an AX5 tranny if that makes a difference.
Originally posted by betterthanyou View PostSame here. That page was too unorganized for me to read all the info though. A new flywheel will work fine.
do you think the camaro/firebird 3.4 flywheel will work fine? Because that will probably be cheaper than having the machine work done.
maybe I am blind but I don't see what you are talking about. I read the part about them having the flywheel neutrally balanced, but I do not see where they are saying you have to do this as opposed to buying a newer flywheel that is already neutrally balanced.Originally posted by agamemnon View Posthttp://www.lunghd.com/Tech_Articles/...Project_XJ.htm
it has an explanation on why u want to use the externally balanced flywheel and have it neutrally balanced
I may give it one more shot then before I take it to a shop. I am going to have to drop down in drill bit size if its going to work, because there is not much material left.Originally posted by Canyonero View PostYeah, you can't drill the extractor itself, gotta remove material around it. My 3.4L had a couple broken studs in it too.
I need to get it out because it's on the 3.4. I have not even tried to pull the manifolds off of the 2.8 and to tell you the truth I doubt I will. I will probably just cut the y pipe so I can take the oil pan off.Originally posted by Canyonero View PostWhy do you need to get it out? Isn't that in the engine you're replacing?
I had that problem when I used the wrong size extractor and broke the tip off. I destroyed some drill bits drilling around it the broken extractor and chiseling it out so I could re-drill and use the correct size. Wasn't fun, but I got it out.
as for the stud, I tried drilling it again after I broke the extractor in it and I could not drill it, no material was coming out at all...that's when I gave up.
If you have broken and easy out off in the bolt then you pretty much limited yourself to welding a piece of metal to the stud and trying to get it out. Welding something on will also rapidly heat the broken stud hopefully breaking it free. My Trooper also has a broken bolt on the exhaust manifold where the PS pump bracket mounts.
