3400 mount info
  • 3400 mount info
    I have a 89 cavalier and am doing the 3400 swap, I am curently in a bit of a rush and don't have a lot of time to order things off the internet. I know who makes and sells the front engine mounts but is there any one that can tell me the dimensions of the mount it's self so I can fabricate one myself.
    Also where are you supposed get the vacuum supply for the EGR from? I have a 91 parts car and I could take the EGR off from that, but it is just electronic so would I have to run the computer from that car? Which computer will I be better off using in the long run? The 89 was originally an automatic, and I'm using the 5 speed out of the 91. Any help will be greatly appreciated.
    Thanks, Paul
    91 5 speed wiring harness, ecm and egr would be the best way to go
      i have the jbodyperformance mount, i would go take measurements but i dont have any way to get the angles measured... its kinda a complex mount. if your in a hurry dont get the jbp mount, mine took at least a month to get
      there is a picture if it helps any
