I am putting a 2002 3400 into my '86 fiero that came with a 2.8. I want to run a set of headers that are designed for the 2.8 to make exhaust routing easier and gain a little performance. My plan is to buy the headers and cut off the flanges and weld on some 3400 flanges so they will bolt to the heads. The primaries are 1 1/4" I.D. so they shouldn't hurt performance from size, and gain a little from better routing then the manifolds would have. My questions is this: The 2.8 headers are designed to have the exhaust mounted vaccuum style 2.8 EGR, with my swap I will be using a digital EGR(top mount style). Could I just mount the EGR in place of the 2.8 (mabey need an adapter) and run the flex tube into the intake (side mount EGR style intake)? OR would it be easeir to use an adapter (side mount to top mount) on my intake and run the flex tube into the header and weld a fitting onto it and eliminate the 2.8 mount on the header? There are pics of my swap on the fiero thread.
I know this is kind of confuseing, sorry, but using three different engines to make one working car gets that way. If more info or pics are needed let me know.
