I want to put a 2005 3400 impala motor into a 2000 impala that already has a 3400 but also has a cracked block. I found the 05 motor with only 10,000 miles for 500 bucks so i want to use it. The problem is they tell me it wont work. I dont believe them. Did research, pcm pigtails are same from 2000 to 2005. Everything seems same except for cam sensor. They redesigned the cam sync ring and changed sensor. Both are three wire connections. Can i spice wires into new cam sensor and do you think the pcm will need changed. Any quick responce will be appriciated
05 impala 3400 into 00 impala with 3400
it will work.
i have an 05 3400 from an impala in my car.sigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
