The minivans did too. 3400 with 4T65E. I'm not sure about the pin outs, you would probably need all the info from alldata or the like for both vehicles but a 97+ minivan computer and harness from either a minivan if you can make it stretch or a 3100 W-body should do everything you need it to do. I don't know how different the computer pin out, firewall connector pin out, or transmission connectors are but they should be able to work.
With all of that it might be easier to make your existing setup fit physically and then get the base tune from someone with that information.
