The engine on my 97 Pontiac GP crapped out on me yesterday. I found a good price on an 03 GP engine that is also a 3.1L... Would these 2 engines be an easy swap, or would it require a lot of modifications??? I need help with this ASAP. I figured it would be pretty easy since it is the same body style. Please let me know
97 Pontiac Grand Prix 3.1 for '03 Pontiac Grand Prix 3.1
The '97 has a different EGR setup than the '03. You could get a 96-98 maybe a '99 3400 upper plenum which has your style EGR, bolt it to the '03 engine, and go from there.Brian
3400 SFI V6, 4T60e
Although the 97 has the different style EGR mounting than the 03, both EGR valves connect the same and electrically work the same, so as long as you use the respective intake and pipe for the EGR Valve, you're fine.
Cliff Scott
89 BerettaGT
89 Volvo740Cliff Scott
89 BerettaGT
04 AleroGX
No. 3100 only, no 3400 in the GPBrian
3400 SFI V6, 4T60e
RE: 3400 in GP
Earth To scotty! Holy old-post spideyman.
Um...also the SE's could get the 3100 Vin "M" (L82 for all you smart highschoolers who speak in code) from '97-98! Maybe even early '99
Brian
3400 SFI V6, 4T60e
