Okay, this is an easy one for someone whos been down this road.
My 3100 runs in my fiero now, and I am able to drive it in and out of the garage. the check engien light is on, so I took the scan tool and pulled the code. It is for the coolant temp sensor, which isn't connected. It's a one wire sensor on the 3.1, but a 2 wire sensor on the 3100, which everyone knows. My question is this, I have a 3100 coolant temp sensor. can I get away with just connecting the signal wire to the green coolant temp sensor wire on the 3.1 harness, or do I have to ground the black wire to the block as well? I am trying to use the 3100 sensor to avoid using a helicoil to install the 3.1 sensor.
Thanks in advance for the help!
Chris
Chris
