I went to a ceramic clutch because I didn't get very much life out of a conventional clutch. I think I had over 40K on the ceramic. I attribute it to being on/off. There really isn't a lot of clutch slipping required once you get the hang of driving a ceramic clutch.
For my F40 swap I opted for a Tilton 7.25" dual disc rally clutch. Mainly to handle the torque I plan on making and because they are fairly inexpensive.
I'm not sure how long this transmission will last with that clutch... but the F40s aren't that expensive at the moment.
As far as needing a dual mass. I've heard from several sources they aren't required. After thoroughly inspecting the stock G6 flywheel and opting to not use it for a bunch of reasons one of which is the torque limiting ring, the second the weight (it weights upward of 25 lbs).
I think a lighter clutch/flywheel assembly with lower inertia will ease the problems with harmonics since the frequency mode is higher given the forcing function input. But I guess I'll see. I actually half expect to blow a tranny up on the dyno when I crank the boost up... though there are videos of the F40 transmitting almost 500 HP (with no shock loading)....
