OK, here is the deal. I have this 3100 running with a carb. No O2 sensor, no EGR, no crank sensor, in fact the only sensors on the engine are the temp sensor at the thermostat housing and the oil pressure sensor in it's normal location. It does have the spedo sensor on the transmission but that is not on the engine. I have a fuel pressure regulator to get the fuel pressure down to 3 psi for the carb, I think I need to know what to do with the other connections, like jump them? leave them hang? anything to trick the car into running with this setup. I kind of think it will throw some codes, but all I want it to do is run the fule pump and it would be nice if the tach worked as well as the oil pressure and the temp gauge. Any suggestions? Anyone done this? For those who haven't seen the setup here is a little video: PS, it has points in the distributator.
Here is a short video of the thing running:
