Well it was the only way to use the 4T65E that came with the 3400SFI. That was one of the criteria... OD.
1986 Fiero-ghini Countach. I have fuel pump relay issues, fuel tank pressure sensor issues, oil pressure switch issues, blah, blah, blah.
Also, it's turbocharged. I am retaining the MAF setup and stock injectors with a 4:1 FMU. We should be o.k. to about 6-8psi. But I need to get it to run more than 3-seconds.
Any OBD-II tuners out there?
