You're right about the throttle bodies, they are the same between 89 and 93. 88 and older are different, though only slightly in the linkage area. The J and L bodies share the same TBs, and the W bodies got a different TB (different linkage).
There are 3 different "style" of Gen II plenums. The early style got the pcv attached to the lower intake, the second got the PCV attached to the upper intake, but basically the same as the earlier, and the final came in 91 or 92 I think where they changed the bolts for the plenum, and added those rubber grommets around the plenum bolts.
This is just what I've observed, I don't know casting numbers or if I'm 100% right about these.
Later
Later
