I talked to a guy at fuelinjection.com. Got a quote of $495 for a standalone engine harness and $175 for reprogramming the ECU. I must say, I'm tempted. It's a fair chunk of change, but will simplify my project.
I've been going over the Firebird and Trooper wiring diagrams. Troopers are simple. Or complex, however you want to look at it. The ECU appears to only manage the engine, no A/C, cruise, gauges, etc - those things have their own controllers and sensors. So I think the Trooper will be fairly ignorant to what engine is actually in there. A standalone harness that terminates all the extra functionality of the 3.4's ECU should do fine.
But, that also means that it may not be a big deal to use my 3.4L current harness. Only thing I'd really need to wire up is the power, fuel pump relay and check engine light. I think I have the ECU and harness from an auto though, in which case the F.I. guy said I'd need it reprogrammed, hence the $175. I think I'll be better off coughing up the money...
