I'm looking at geting a new set of light weight rims. 8.5 in wieth what offset should i be lloking at, I'd lick the tires almost to the fender?
rim offset? biger or smaller to move the tire out?
2002 Pontiac GrandAm GT1
3400 v6
TOG headers
RSM 62MM T-body
FFP underdrive pulley
GRANATELLI MAF
Ported upper intake
MSD DIS 4 ignition box
MSD Wires and coils (pending)
Venom high flow fuel pump (pending)Tags: None
Stock offset is +42mm; you want to move closer to +35mm. Test fit if at all possible before buying though.....I only went to an 8" wide rim (+35mm offset, 225/45R17 tires) and things get tight at full steering lock.Matt
