I have a 98 Lumina with a 3100. I replaced the LIM gasket late last summer and, at that point, I didn't need to use the AC. We are starting to get the hot weather and I found my AC is not blowing cold. I figure top it off as your supposed to run the system 5 minutes a month to keep the seals in good shape, I didn't run it this winter. Prior to charging, I decided to check the low side pressure to see approximately how much I need to add. I have checked with two different gauges to be sure, but the pressure is 50-52psi (depending on gauge) at an ambient temperature of 80 degrees f. My reading of the gauge 1 information says I should be at 25-45psi @ 75-85degF for proper fill; the gauge 2 information says that I should have 40-50 psi @ 80degF for proper fill.
The high side pressure is 52psi, but should be 175-250psi @ 80degF. On the gauge's troubleshooting information, it says if the low side is running high and the high side is running low along with a wildly vibrating gauge needle would be the reed valves in the compressor and the compressor needs to be replaced. I didn't notice the gauge needle vibrating at all and really was consistent.
Could this be a bad compressor (it doesn't make any rattling or whining noise, it sounds normal) or is it something else-->dryer, evaporator, clogged orifice tube? I have not opened the system at this point. Any suggestions would be appreciated.
