I've got the '95 Ga (170,000, still alive!!!!) SE. Seems that unless the car had rear disc brakes, there was no rear sway bar. Hell, i have been under the car a million times trying to figure out what and where the sway bar would get attached to. I looked under a gt, of course it has the reardisc brakes. It seems that the whole rear axle beam is different on a gt, and the gt has the monting area right beloew the rear shock mounts. I don't have any thing. My car has ureathane bushings in the control arms, higher durameter bushings in the rear axle beam, uerathane bushings in the front sway bar, plus the front came with the Gt bar, and uerathane end links, front srtut tower bar, Moog higher duremeter strut bushings too. Needless to say the front end is nice and stiff. Tracking is great too ( for sensatracs any way) I just need a rear bar. Any help is graetly apperiacted.
P.S. If you have all those mentioned bushing replace with the good stuff as i did, have DEEP pockets. The labor on the rear beam was unbeleviable.
