HELP ASAP
  • HELP ASAP
    Will 20's fit under the front suspension of a 92 Z34 Lumina. Tire size is 225/35/ZR20 HELP ME ASAP
    RE: HELP ASAP
    Looks like it to me. Your diameter is almost exactly the same and so is the tread width. Go for it.
    Check this out to see for your self.
    Your stock size should be 225 60R-16
    Lyle
      they will but unless you gut the fender wells, they will rub like hell
        Why would they? Same tread width and diameter. What difference would it make if they are 16" rims or 20" rims?
        Lyle
          im not sure why, but i had a set of 20's on my old Berette and they rubbed like hell
            well a beretta is a smaller car isn't it?
              since it was so urgent, you prob dont need this info, but if its the same width and circumfrence/diameter no prob cept for maybe bottoming out easier due to much much stiffer sidewall
              91 GTP HM-284 GONE
              96 Special Edition LQ1/4T60E GONE
              98 Spawn of Satan (L67 Regal)
              87 V10 SM-465/Mild 350
              06 Cobalt SS/SC GONE
                they will fit fine...like my welder friend says if it fits and rolls, its good. You might want to consider a suspension upgrade to avoid bottoming out for real. My car does it now with 18's on it so I can only imagine 20's.
