hey i am looking at getting a lsd unit for my trans is the phantom grip any good ? i was looking at a team green today but i dont think he makes them for my trans.and i know that the E.P is the best but i dont really want to spend that kind of money on the trans. so is the phamtom grip good enuf for a mild project or is it a POS unit ?
limited slip diffs
People over on the Fiero board have had the phantom grip blow up on them.
Granted, it is the GETRAG's that blow up, but seeing some of the carnage pics, it makes me hesitant to trust them.Taylor
1998 Lincoln Mark VIII
mpracing.org/store sells LSDS through EP. Be warned that you could be waiting for up to 6 months for a LSD. If you order a LSD through mpraicng you should it sooner because both you and mpracing will be asking for the lsd to be complete in a timely manner.
The delay is because Jeff is working the shop by himself. Until he gets help then the shop should speed up.Last edited by blackbombshell95; 11-27-2007, 07:06 PM.
I've got the team green insert in my 282, i'm not overly impressed but it did help with the torque steer.
I'll pull it out soon and inspect for damage, i've got a little over 1K miles on it.
the EP ones are pretty much the same design that i've seen in stock GM LSD rear ends and Ford as well..Originally posted by blackbombshell95 View PostMY lsd/trans build from EP should arrive by the first of december. I expect great things. I also found that dynotech also sells EP lsds which must mean that they are pretty good.
kind of a tried and true design, Maybe someday i'll pick one up...
I'll let you know. If you order a LSD order through mpracing.org/storeOriginally posted by 19Cutlass94 View PostBe sure to let us know how that tranny works out! Im interested in buying stuff from them!
If all goes well it will be running by the 2nd week of December.
LSD. 3.73 gears. 3k stall. EP shift kit. All newLast edited by blackbombshell95; 11-27-2007, 07:07 PM.
Originally posted by blackbombshell95 View PostI'll let you know. If you order a LSD order through mpracing.org/store
i only see it for the 4t45e and 4t40e..they use the same diff as the 4t60e?1994 Chevy Corsica. Parted out. Just a rotting shell now
Best 1/4mile ET - 12.9
Best 1/4mile MPH - 111
1997 Ford Ranger Splash
Daily Driver
Wouldn't count on it. 40 and 45 are physically smaller than 60, iirc.Originally posted by loner666 View Posti only see it for the 4t45e and 4t40e..they use the same diff as the 4t60e?Kaiser George IX: 1996 Buick Century Special wagon. 213-SFI. 250k miles. Never gonna give you up, never gonna let you down. First documented LX9 swap in an A-body! Click here to read my build thread!
The diffs are different. Contact Mark(mpracing owner) and he should be able to get it for you.Originally posted by loner666 View Posti only see it for the 4t45e and 4t40e..they use the same diff as the 4t60e?
I should add that Mark is a great guy and a great seller. I've made 2 orders from him and they went smooth as possible.
