Ok, so I guess it's time we settle some things, since I'm bored and my 282 is sitting partially disassembled on my workbench.
To the best of my knowledge, my 282 (RPO: MG2) came out of an '89 Cutlass International. I'm 75% sure that w-body bolt-in 282s came ONLY in w-bodies; meaning that no other 282 case has the mounting provisions on the bottom for our subframe-tranny mount. As with all other W 282s, the slave cylinder is externally mounted with an internal arm/fork setup. The trans has the old style (pre-'91) differential, which has a cast finish, a larger diameter pinion shaft (chrome in appearance) small spider gears and a 34 tooth gear for the Hall Effect electronic speedo sensor.
The '91+ 282/T550 differential has a machined finish, larger spider gears, a smaller, but hardened, black pinion shaft that lacks the grooves the old ones do, and is much stronger. Thanks to Fierobsessed from fiero.nl for that info.
The following numbers are tooth counts for each gear that I just went out and physically counted myself.
Input shaft
Input splines: 14
1st drive gear: 14
2nd drive gear: 20
3rd drive gear: 24
4th drive gear: 35
5th drive gear: 43
Output shaft
FDR drive gear: 18
1st driven gear: 49
2nd driven gear: 41
3rd driven gear: 33
4th driven gear: 33
5th driven gear: 31
Reverse gear: 41
Carrier
FDR driven gear: 65
VSS ring: 34
Reverse Idler Shaft
Reverse idler gear: 29
The following numbers are from a 1987 "Muncie Getrag" 282 service guide from GM. I think Rodney Dickman had it hosted.
1st: 3.50:1 - drive: 14, driven: 49
2nd: 2.05:1 - drive: 20, driven: 41
3rd: 1.38:1 - drive: 24, driven: 33
4th: 0.94:1 - drive: 35, driven: 33
5th: 0.72:1 - drive: 43, driven: 31
R: 3.41:1 - drive: 12
FDR: 3.61:1
The only other listed options in this '87 guide was an alternate for 2nd: 2.19:1 - drive: 21, driven: 46, which went into the MG1 trans and the alternate VSS sensor rotor with 28 teeth. I wish I could find a newer guide to get some of the later gearing straightened out.
But there you have it. W-body V6 Getrag 282 gearing is 3.50/2.05/1.38/0.94/0.72/3.61. This is the numerically lowest/longest gearing available for any 282 trans, so any hopes of swapping gears from other 282s to lower the revs a little are gone.
I'm trying to get a full page together on all the Getrag/Muncie/NVG 282 information out there, but it could take some time. There's a lot of conflicting and unknown information out there.
Input shaft
Input splines: 14
1st drive gear: 14
2nd drive gear: 20
3rd drive gear: 24
4th drive gear: 35
5th drive gear: 43
Output shaft
FDR drive gear: 18
1st driven gear: 49
2nd driven gear: 41
3rd driven gear: 33
4th driven gear: 33
5th driven gear: 31
Reverse gear: 41
Carrier
FDR driven gear: 65
VSS ring: 34
Reverse Idler Shaft
FDR: 3.61:1
