SPEC Clutches??
  • SPEC Clutches??
    I just ordered a new clutch for my 1991 GTP it has the Getrag 284 in it, anyways i got it from http://www.specclutch.com its a Stage 3+ cost me $850 US. has anyone ever purchased one of these clutches? if so how is it? i got this because of my turbo project and im sure a stock clutch wont hold up to it. anyways if anyone has tried it then let me hear it.
    Jake
    from what I know they will chatter and be very abrupt...They will smooth out with age and use. very agressive friction material
    Lorenzo
      $850 for a clutch?!?
      i got a stage 3 clutch, 2x pressure plate and an aluminum flywheel for the same price.
      www.clutchnet.com these guys make good clutches and pressure plates. as you know any neutrally balanced 282 flywheel will work. i believe i bought mine form the fiero store.
        well apparently the stage 3+ is way better than the stage 3 , not as harsh as engagement, and full disc, made from carbon metallic , also can handle up to 850hp. so i guess it better be good, lol . plus a stock clutch around here cost about the same so i figured i had nothing to loose.
        Jake
          WOW. i just got a clutchmaster stage 3 for $540, i thought that was expencive.
          i had a stage 2 spec clutch, i will never buy one again. it lasted maby 3k (it riped apart literally). and after a few runs it liked to slip. it was also a pain to drive (also had a fidanza flywheel)
          i know there has been a lot of people that run them and love them
          http://www.ultrarev.com/home.php?cat=326 they seem to have better prices on spec clutches
          [SIGPIC][/SIGPIC]
          [u][b]88 Beretta CL[/b][/u]- 13.641@102.76mph (rwd LS1/t56 conversion in progress)
          [B][U]77 Celica GT[/U][/B]- 3400/3500 swap in progress (engine from the beretta)
            asdf
            -Tony | [url=http://www.gtsdurango.net/?p=w]gtsdurango.net[/url]
            '04 Dakota Quad Cab SLT 4x4 - the gas guzzling DD.
            '90 Turbo Grand Prix STE - ehh.. I'm working on it.
            '92 Gutless Supreme SL - RIP 5.2010
            '90 Turbo Grand Prix - RIP 6.15.2005
              His is more expensive because he has a Getrag 284. It uses a different pressure plate and throwout bearing. It's pull-style..
              I had a Spec Stage 2 and it was a wonderful clutch. I have a Spec Stage 3 now because I plan on making more power. It chattered for the first 500 miles but once broken in it stopped chattering. It engages very smoothly.
              [img]http://stsnyder.bol.ucla.edu/avatars/redcarsig480x108.jpg[/img]
