I have a 95 GP that threw a rod so i swapped with an 01 Montana 3400. I switch the intakes & plenum over, all the sensors look pretty interchangeable. Now the car needs to be revved before it will move. Reverse is fine, manually shifting into 2nd, 3rd, 1st don't change it, the 2nd spd start button does not affect it and I unplugged the traction controll (ABS PUMP) just to rule out a brake issue. On the road when i go thru the other gears it works fine. Any help would be greatly appreciated, this car is making me CRAZY(ER). brian
4t6o slipping in first gear
You can check the forward servo on the back side of the transmission. You have an H-body I assume, it will be very easy to get to. Check for a craked piston or a bad seal. 3 8mm screws and its off.Last edited by gpse3400; 07-17-2008, 10:50 PM.Lorenzo
