what would happen if i just made a solid diff?? would it break anything in the trani when i turned or would it just hop a little?? i am having traction issues and just thought about doing it.
solid diff
solid diff
1996 Beretta
3100 SFI TURBO
T28 60 Trim Turbo at 9psi, Stage 1 turbo cam mms, lifter upgrade springs mms, P&P heads, ls6 Valve Springs, Ported exhaust manifolds, Hyperuetectic pistons SP, 3.29 trani, MSD 8.5 wires, open exhaust, Pulstar plugs, 3400 intake manifolds, ported TB, 36 lb/hr injectors, RCI Fuel cell, Walbro 255 pump, A/C Bypass, and much more.
13.1 @ 103 mph best in the 1/4 mileTags: None
the tires will squeel around corners at lower speeds.. at higher speeds you'll lose traction turning.. even worse in the rain/snow.
LSD is the way to go if you drive it on the street...
spool or mini spool??
1996 Beretta
3100 SFI TURBO
Spools are basically a solid piece of steel that replaces a diff. They're generally not recommended for anything outside of dragracing. They also add a huge amount of steering effort on a FWD car and a lot more treadwear.1995 Grand Am SE
You should not lock a front wheel drive diff... end of story, unless you trailer the car to the track.
If you drive it buy an EP LSD, it will make driving possible and also improve traction.
The problem being, afaik they dont make a spool for a fwd style diff. you could prob modify a mini spool to work, but yah you would be breaking the output shafts right a left on the right and left, lol, due to all the added pressure and your tire trying to force its way faster than the inside tire. you could just weld the gears in the diff old school style, but thats not recommended either
Exactly. People wouldn't even weld the front in a 4X4 you can't turn worth shit. If you had any scrub radius in your steering system you would never be able to turn the wheel at all unless you were moving. And even when you were turning you would vastly increase the turning radius of the car making it very un practical. Then add in all the parts wear and breakage and you could easily pay for a pair of slicks for the track or a LSD.Originally posted by 3400-95-Modified View PostYou should not lock a front wheel drive diff... end of story, unless you trailer the car to the track.
If you drive it buy an EP LSD, it will make driving possible and also improve traction.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
already got slicks and my problem is that one tire will break loose then the other back and forth until i get a ways down the track. i need at least an lsd.
1996 Beretta
3100 SFI TURBO
Then call or e-mail Jeff at Engineered Performance, your looking at 600+ or so for a LSD for a 4T60E setup($599 LSD cost unless winter sale of $499, not sure if he does that anymore, then 150+ for output shaft) the same style I'm using, machined steel plates and modified output shaft to resemble 4t65e style, No removable clip, it's like the axle clips that hold it in the diff making removal easy.
Dont forget the unknown wait time. Thats one thing that stops me, among the fact that I dont have close to a grand to drop on a diff setup and I dont have a spare diff anymore (Sold it to a better cause. lol). I do need something though if I keep my setup. I really do hate the one wheel wonders and fighting the car the whole way down the trackOriginally posted by 3400-95-Modified View PostThen call or e-mail Jeff at Engineered Performance, your looking at 600+ or so for a LSD for a 4T60E setup($599 LSD cost unless winter sale of $499, not sure if he does that anymore, then 150+ for output shaft) the same style I'm using, machined steel plates and modified output shaft to resemble 4t65e style, No removable clip, it's like the axle clips that hold it in the diff making removal easy.1994 Chevy Corsica. Parted out. Just a rotting shell now
Best 1/4mile ET - 12.9
Best 1/4mile MPH - 111
1997 Ford Ranger Splash
Daily Driver
Wait or break... some things are worth waiting for.
