i have heard that our trannies the 4t60e had as much as 5 different fdr's in them. how do u tell which one u have?
final drive ratio/differential
kewl, how do i do that and where do i get a 3.33? also i have a 3 spd auto for a 86 fiero gt. mybe that might be a potential donor for a diff?also if quantum is right u guys can delete the thread and i will re-post. i didn't intentionally screw up the order.sry
any 4t60e with a 3100 motor in a w-body. You'll need the differential, sun gear, and possibly a shim/washer/clip. Lorenzo would know since he's done this.
You should be able to do it from the passenger side wheel well, its not gonna be easy but it is possible. On the 3.4 you'll have to remove the rear motor mount and bracket, remove the axel, and possibly undo the tie rod from the knuckle.
If your alternator is starting to die you might as well do that along with it since it will be much easier to get out.
i've done it to. u are supposed to use a special tool from gm to measure the clearance so u know what spacer to useOriginally posted by brian89gpany 4t60e with a 3100 motor in a w-body. You'll need the differential, sun gear, and possibly a shim/washer/clip. Lorenzo would know since he's done this.
