09 cobalt ss trans
    replied
    Originally posted by torq455 View Post
    i think that tranny has horrible ratios. 1-2 difference is like my auto, then why bother with having 4th gear? 3,4, and 5 are so close together. all that torque, why not actually give it a real OD? it's also already at it's max torque capacity.
    ENTER the confusion that is GM...
  • torq455
    replied
  • Alxsmt
    replied
    lol i wanna turn tho....
    replied
    Meh, just weld the gears in your HM282
  • Alxsmt
    replied
    so it wont work for sure? i havnt had too much time to research the fiero forums yet
  • Joseph Upson
    Guest replied
    The Cobalt SS and Saturn Redline get the 5 speed from the Saab cars which the 6 spd F40 used on the 06-07 G6 originated on. The non boosted models get the Muncie 5 spd. You will not be able to swap bellhousings with anything else to my knowledge due to the transmission being a Saab part used on an American vehicle. It's stronger than the Muncie so it was placed on the boosted versions of those two cars.
    The F40 6 spd is not a Muncie tranny, although GM did make the alternative 60 deg bellhousing for it.
    replied
    I actually copied that off of the Cobalt spec info, so not sure why it only lists the HHR...
    replied
    4.05:1? damn thats a short final gear...
    or is that the HHR only? i imagine the cobalt would get a more streetable final drive...
  • Alxsmt
    replied
    i may have to do some comparing this weekend
  • Alxsmt
    replied
    hmm if that would work i could stay in 3rd gear for drag racing.. im not sure if that would help or hurt
    --------1----2-----3------4------5
    500----2.6---5.0---7.5----9.9----12.6
    1000--5.2---10.0---14.9---19.8---25.2
    1500--7.8---15.0---22.4---29.7---37.8
    2000--10.4--20.0---29.9---39.6---50.3
    2500--13.0--25.0---37.3---49.5---62.9
    3000--15.6--30.0---44.8---59.4---75.5
    3500--18.2--35.0---52.3---69.3---88.1
    4000--20.9--40.0---59.7---79.2---100.7
    4500--23.5--45.1---67.2---89.1---113.3
    5000--26.1--50.1---74.7---99.0---125.9
    5500--28.7--55.1---82.1---108.9--138.5
    6000--31.3--60.1---89.6---118.8--151.0
    6500 33.9--65.1----97.1---128.7--163.6
    7000 36.5--70.1----104.5--138.6--176.2
  • HayesPerformance
    replied
    I thought that the only new manual tranny that would work is the getrag F40
    replied
    Kind of looks like it...
    Specs on it don't look that bad either...
    2009 GME Sweden F35 ( MU3 ) 110607
    Type: transverse front wheel drive, five-speed manual transaxle ( optional with limited slip differential )
    Engine range: 2.0L I-4 turbocharged (LNF)
    Maximum engine torque: 260 lb-ft ( 353 Nm)
    Maximum gearbox torque: 260 lb-ft ( 353 Nm)
    Gear ratios: MU3
    First: 3.38
    Second: 1.76
    Third: 1.18
    Fourth: 0.89
    Fifth: 0.7
    Reverse: 3.17
    Final Drive Ratio: HHR SS - 4.05
    Maximum validated gross vehicle weight 2300 kg
    Case material: aluminum
    Center distance: 76.5mm
    Fluid type: Castrol BOT 0063 or BOT 0402
    Transmission weight: wet: 45 kg ( 99 lb )
    Fluid capacity (approximate): 1.7L / 2.0 qt. ( dry )
    Power take off: no
    Applications: Chevrolet HHR SS
  • Alxsmt
    started a topic 09 cobalt ss trans
    09 cobalt ss trans
    long story short, i just found out that the 09 cobalt ss turbos (2.0L) have the gear style LSD. i would love a modern tranny and i had a thought
    is this like the quad4 trannys where u can swap the belhousing and bolt to a 60*? or maybe steal the diff? i figure its a longshot but couldnt hurt to see if any1 happens to know. i have no idea of its a totally different animal or just another updated trans
