4T65E 2002.
Transmission was slipping in 1st and 2nd, pretty bad.
Bought a trans for $400 with converter, used, claimed 30k miles on it< same codes PAB.
Spent the day swapping the trannies.
Started it, started to fill it, put in 2 quarts, it still had tranny fluid in it. Checked it, needed more. Added another quart, motor tone changed, total run time so far, is roughly 1.5 minutes. Heard gurgling noises, checked it, needs about a quart more, haven't taken it out of park yet. about 2.5-3 minutes of run time. Start to give it another quart, motor jumps like a miss, once, runs for 3-5 seconds more and stops....hard. hmmm something ain't right.
Crank motor, it fires and stops again.
try to crank again, locked. will not spin.
I have never seen a trans lock up like this before. Put it in neutral and you can push the car, still won't spin in neutral.
Any ideas? Or did I just get a bum trans?
