i have a '91 caddy with transverse mounted v8 and 4t60-e that is bad. i have a donor car '92 euro with 4t60. need to know what is needed to pull off this swap. if i mount the throttle valve linkage will this do it?? the wire plug is different on the 2. thanks......
need help: swapping backwards 4t60-e to 4t60
As long as the TV cable and vacuum modulator are hooked up it will shift. But if you want the lock up converter then you'll need to contend with the main wireing harness. As for the axles I cant say that the length will be correct/ you are better off finding an axel to that car at a time it ran with a 4T60/ 440-T4.Lorenzo
