Getting ready to remove the 282 so I can change out the bad TO bearing. So far I've removed the axles, starter, x-over pipe and some other simple stuff. It looks really straight forward.
Question 1: Are the 5 bolts easily visible from the top the only ones holding the trans to the engine itself?
Question 2: When removing the trans after its all unbolted does it have to push away from the engine at all? Reason I ask is because there is sheet metal from the fender well that will be in the way, granted once I drop the frame rail the trans should dip enough to clear.
Question 3: Are the following the only electrical connections to the trans?: the VSS, the reverse switch, and a bunch of ground wires on the bolt nearest to the starter.
Question 4: I'm replacing the control arm bushings (despite the fact that they look perfectly fine) and I'm having a lot of difficulty getting the sway bar end links off the contol arm. It looks like its just a stud. All I am trying to do is remove the nut on the top so I can pop the sway bar off and remove the control arm - not remove the entire end link. The nuts are just very resistant to turning despite how well I cleaned the threads and made use of penetrating oil. Unfortunately, I sheared one of the end link studs (drivers side) and I see no way to get the end link out of the control arm. Anyone know how to do this and if replacement end link 'studs' are available?
I'm sure I will have more questions as I proceed.
Thanks!
Thanks!
I'd forgotten all about that thing being there... I had a Haynes manual on hand when I had mine apart, so basically I used that as a reference to see what all had to be done to remove the trans... but at the moment it's packed away somewhere...
