Hi All,
I have a 1995 Chevy Corsica with the 3100 and 4t60E transmission.
At highway speeds under even the slightest load like going up a hill it feels like it has no power (TCC still engaged?) then it feels like it might be slipping somewhere then suddenly grabs and goes. There is no tach so I cant really tell very well what the engine is doing. I have read about a lot of different TCC problems with these transmissions (stuck TCC valve, leaking TCC valve, bad TCC solinoid, bad PCM TCC solinoid driver or a bad vacume pressure actuator). Is there anyone with enough expertise to help me differentiate between possible problems? I thought it was the 4 gear clutches so I "shotgunned" a transmission with 51K into the car. I changed a bunch of other stuff while I had the motor out so it wasnt so bad. It was working great for about 2 weeks, but now the same old problem is back, which invalidates all the other work if I cant nail this problem.
Other things that I replaced before doing the transmission were engine position sensors, TPS, FPR, fuel filter, plugs and wires. I have not replaced the MAP and have read that this helps the PCM determine engine load for unlocking the torque converter. I am going to check this out with a DVM and hand-vac this weekend.
Thanks for any help!
