just like clutches, lock/unlock, engage/release: every time it does it, it wears it out a little more, and eventually it will fail. granted ~50K miles isn't that much, but who knows how those miles were driven.
EDIT: and removing the PWM wire from the equation will just only allow 100% apply or 100% release, nowhere in between. it's strange that GM decided to use two circuits here, but it works. when the PWM solenoid hits 100%, the on/off solenoid goes on and the PWM probably turns off(i haven't had a need to deteremine if it does or not). and then when it's time for release, the solenoid would power to 100%, the on/off would go off, and the PWM would dial down to 0%.
at least that's what i'm being told from alldata.
