anyone know where I can get a clutch for a combo like that?
F23 transaxle/3500
Use a pressure plate from a 1993 beretta GT 3.1 5-speed and a disk from a 2002 cavalier 2.2 OHV 5-speed.
Then the only variables left should be bellhousing clearance and slave cylinder throw. Those will *probably* be fine.
You should also be able to use a complete 2.2 flywheel, clutch and disk not that I think of it from a 2002 2.2OHV and everything should work perfect. The 2.2 flywheel is a tad lighter too so you can benefit from that. Thats probably your best bet.95 Beretta- Lg8 Daily Driver
