I broke my Muncie 282 5spd at the track, so I'm thinking about an F40 6spd upgrade. It will be going in a 3400 Beretta. I'm not worried about the fab work for a custom mount or the intermediate shaft...my main concern will be the cost of clutch, axles and LSD.
I know V8Archie sells a clutch and flywheel spacer kit for about $800. Right now I have a good SPEC 2+ for the 282, but from what I understand, the input shaft splines are different.
I currently have Driveshaft Shop 282 axles, and they said they could either convert mine or go all new for about another $800. I read about using the 282 outer CV and the F40 inner with a custom bar from Moser and the like. Do you need a donor F40 axle or are the inners available new?
I assume the F40 never came factory with an LSD. Is that correct? I've found a Quaife LSD for about $1000. Does anyone convert a stock diff to LSD similar to what EP does?
Thanks for any help.
