Hello all! Let me apologize for asking a question for my first post, but I have an issue that I cannot seem to find an answer for.
I bought a 94 Skylark with 3.1l v6 in 2006 with 137k on it. Around 175k the 4T60-E would not shift out of 1st. I got a used junkyard 4T60-E with 58k out of an unknown donor in 2009 and had it installed. Ever since then I do not have 4th gear, or ANY shift light. I took apart the instrument cluster and verified that the light functions, but it will not illuminate in any gear. The transmission shifts 1-3 perfectly, no slipping, no other issues, however with the rising cost of gas prices I would greatly enjoy the O/D gear. The shift light is less of an issue, but I feel it's related.
Now that the car has 215k on it, and still running like a tank, I'm about to drain the trans fluid and replace the filter as preventative maintenance. I figured this would be a good time to do any repairs while I have the pan dropped. Do any of you have a direction in which you can point me for looking into what needs to be replaced? Or even better, a part that you are pretty sure will fix it. Or best yet, an actual part number/link to a replacement?
I have done quite extensive searches of this forum, the Buick and GM forums, and other websites, but have not found much information that is relevant to my problem. Most places point to loss of 1st and 4th, or slipping/clutch problems none of which are occurring with my transmission. As I stated previous, the 1-2 and 2-3 shifts are smooth and precise both up and down shifting, it just seems like the transmission doesn't acknowledge that it even has a 4th gear. Well, smooth unless I'm at WOT, then the shifts are sharp and precise...exactly how they should be. (Yes, the car can still hit the limiter and ask for more, even with 215k. Gods I love this engine.)
Glad it was a simple fix, too.
