Quick! Can somebody give me a part number for a 3500 clutch pilot bearing? Will a 3.4l pilot work?
Clutch pilot bearing for a LX9 3500?
TKO uses the same output shaft pilot as a T5, So were good! OK! Ill go ahead and order it online. I wont be dropping in this engine till next monday, anyway.Originally posted by caffeine View PostOnly RWD engines got pilot bushings. 2.8/3.1/3.4 pilot bushing is the one you want. Assuming your trans has the same input shaft diameter as a V8 T5 a 3.4 pilot bushing will be fine.Took a break from working on the car. Got some better tools, got a better shop, got a better job... Its time to burn metal!
