Hey all,
I read the article on 60 degree for swapping to the 284 as I will be doing this swap on my 93 GTP sometime in the next month or 2 and I need some help with the electrical side. More specifically, the Clutch Start Switch and the Shift Anticipate Switch.
The writeup only mentions the anticipate switch (the 4 pin one in the pedal assembly bracket) but there was no mention of the start switch (the big switch that is mounted to the floor that the clutch pedal strikes when FULLY depressed...2 pin I believe...would have to look at it again). Also, the instructions are not clear on exactly how the anticipate switch needs to be wired in.
Does anyone here have any knowledge/experience with this part of the swap? Any help would be GREATLY appreciated!
Thanks,
Paul
Thanks,
Paul
