Transmission pan. There is an option for 4t60e
Their is an option for a 4t60e
Transgo shift kit
Are there any aftermarket flexplates/clutches available?
And which GM torque converter would put me around 3k that would fit in my 4t60e?
Transgo shift kit
. For aux coolers, if you want a factory look, you can get the setup from a tdc car, or you can buy a kit from the auto parts store. The best type is the stacked style. You can run thr\e regular tube/fin stlye as long as it has the turbulators in its tubes which basically is a divider that is twisted. Pepboys, AZ, Advance should have one......Actually I got a kit that I'n not going to use. I'll sell it for $50 shipped. It's a heavyduty stack style. Comes with all the quick mounting hardware and rubber transmission hose.
