I tried to install some brand new(new as in no miles but came from crate engine so have been sitting for a bit) 3100 injectors into my 88 Fiero v6.
After,I tried to start it and it didnt' start. I had a pulse signal to the injector so I knew it was getting power. I pulled the injector to check to see if it was spraying and it wasn't. in fact none of the injectors were spraying.
Are the 3100 injectors using a different signal or different impedence then my stock injectors? I am positive it has nothing to do with them coming form a sequential car cause thats all in the computer program. Think its possible that all the injectors are stuck shut? Or is it they need a different signal in order to fire??
Thanks
Thanks
