I've been discussing this engine quite a bit but am not sure if I will invest in the version with the extended fuel management option. As an experiment I pulled one of the injector fuses this morning on the hwy (in my Fiero) to see what the effect would be and amazingly the car continued to run and maintain speed which was only 60 MPH at the time.
Since the valve train was still working unlike in the 3.9 where it shuts down for the affected cylinders, I'm not sure if the vibration which really wasn't bad at all would smooth out even more if it were possible to disable the valves on my current engine. Since I'm not sure of what any potential side effects would be I didn't run the car that way for an extended time.
I believe GM deactivated the valves to reduce the load on the valve train by the non contributing cylinders, however there maybe other dynamics at play such as thermo which would be different with valves opening on a dead cylinder allowing cooler air in compared to them being closed on a dead cylinder where the temperature in the cylinder as well as the pressures would be more stable with the valves closed during fuel saver mode.
If I were not so far away from home I would actually disable one bank on the hwy for a couple of days to see what my fuel savings if any would be like since I travel nearly 100 miles round trip a day at the moment. It's only feasible at hwy speeds since the purpose is to take advantage of a steady state, interestingly enough I didn't have to apply excessive additional throttle to maintain 60 MPH and as those who have driven an engine with a misfiring cylinder would know, the higher the rpm the smoother the engine gets.
This is something to think about because if there is no appreciable downside you can install a switch and shut down half the engine by cutting off one bank of injectors on a long trip and set the cruise control to hold speed, provided there is a significant enough fuel savings which I believe there would be running on 1.7L in a 3.4L engine.
Again the vibration really wasn't that bad and in a larger car maybe even less noticeable.
