Hi,
I'm new here, and I'm doing my first engine swap. I just picked up a 3.4L to swap out my 2.8L in my Fiero. But, the first thing that I noticed was that the oil filter is mounted to a 90 degree adapter on the 3.4L. On the 2.8L the filter mounts directly to the block. Is there a way to change the 3.4L so that the filter can mount to the block like the 2.8L? It seem like it just needs a simple threaded tube that screws into the block which the filter would then screw onto. Can I take this screw "thingy" off of my 2.8L and put it on my 3.4L?
The reason I ask is that I have to relocate the starter to the other side, so it would be nicer if the oil filter wasn't right next to the starter.
Thank for any info you can provide,
Nick DiMonte
Nick DiMonte
!!!!! BOSCH PLUGS RULE !!!!!
