Originally posted by montess408
View Post
gen 1 2.8 aftermarket heads
Your biggest hurdle for the Gen3 heads on a Gen1 block is the DIS conversion (unless you get a 3.4).
so there just a early try at the new aluminum heads of today then so not worth the efort to try to get a setLast edited by montess408; 04-28-2008, 06:18 PM.
Even if you found them, you'd need the matching custom intake manifold setup, as the heads are "complete". In other words, the intake manifold does not complete the top part of the head (like the regular heads). Its not like its just a plug-and-play modification.
I have never seen a set, so I decided to use the Gen3 stuff on a 3.4. It should smoke some LT1 F-bodies after the modsOriginally posted by montess408 View Postso there is no chance to have a set available nowadayz then ?
They are little more than myth. They were so obscure that only race boats and stadium trucks got them.
You are better off doing a FWD head swap.
The Potter heads were basically testing grounds for Gen2 heads
There isn't much info out there and I don't know where the pics are anymore. I was hoping someone else would say more on it.
thanks ben !
do you know where i could see pics of the heads or if there is a web site ??
there were potter heads, and RFRE heads. Perhaps some others but as far as new castings that were aftermarket, that is what comes to mind.
i was reading this here a long time ago that there was aftermarket heads avalible for the
2.8 iron head motor does anybody know what i am talking about or remember the name of them ??Tags: None
