i installed a new radiator fan and i cut off the factory plug to the old radiator fan... and like a dummy i didnt leave a long enough tail to reattach it later.. so now i need to know where i can get these.....
Connectors for radiator fan
Your cheapest bet would be to just go to a junkyard and get the connectors with long enough wires. Buying new connectors (and all the pieces that go with them) is going to cost you alot more.-Brad-
a temp fix if they are the blade type ends. go get some connectors from the local hardware store or if you got some, just splice in the wiring and hook the terminals back up the way they were. make sure you get the insulated ones (plastic enclosed) and go from there till you get a replacement plug.Mike
I was just going to ask the same question?Originally posted by SuzukiGhostRider View PostMay I ask, why in the world did you cut if off in the first place rather than just unclipping it?1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon)
--Mods: 13gs and stuff
