Ok im putting a brand new pulley on my p/s pump and dont really know how far to put it on, does anyone have a pic of how far the stock one is on or have a measurement?
How far to install PS pulley
when I do mine, I just tighten it until it stops. It is usually flush with the end you are installing it on.Taylor
1998 Lincoln Mark VIII
should be flush with the end of the p/s pump shaft...00 turbo'd gagt msd 8.5 mm wires,ngk tr-6 plugs,42.5lb inj,65mm tce t.b,ported upper intake,ported lower,ported heads,copper headgaskets,headstuds,160 stat,ls6 valve springs,st3 turbo cam and pushrods,turbo manifolds,custom 'y' pipe,3in open d.p.,dhp powr tuner,garret t3 60-1 .63 turbine,70 compressor,6 pounds of boost...STOCK CAM,STOCK 103XXX BOTTOM END...2.041 60',13.683 @ 100.34
99 gtp 4in. F.W.I...180 stat..headers...104's...msd8.5's..1.9's...3.4 pulley...cat & res./
