97 3400 transport
  • 97 3400 transport
    what size injectors did they use, and at what fuel pressure?
    i went to the yard today,it was the only 3400 they had
    pressure should be 43.5PSI.... i think they didn't go to like 55psi until 2000?
    flow..... 19lb/hr minimum
    [CENTER][B]1995 Monte Carlo LS[/B] 3100, 4T60E...for now, future plans include [B]driving it until the wheels fall off![/B][IMG]http://i598.photobucket.com/albums/tt68/robertisaar/NewSig.png[/IMG]
    Latest nAst1 files [URL="http://60degreev6.com/forum/showthread.php/48100-nAst1-Progress-and-Concepts-Thread?p=461016&viewfull=1#post461016"]here[/URL]![/CENTER]
    [CENTER]Need a wiring diagram for any GM car or truck from 82-06(and 07-08 cars)? [URL="http://60degreev6.com/forum/private.php?do=newpm&u=9626"]PM me![/URL][/CENTER]
      i have a newer FPR i can put in, what LB/hr would that make them at 55psi?
      edit: i need to know if these can be made to work for a 3500 engine, or if i should buy new injectors?
        here you go all your injector info needs.
        it would make them 22psi which is what the 2000+ ones are.
        [SIGPIC][/SIGPIC] [IMG]http://i60.photobucket.com/albums/h5/95blackz26/sigpic2.jpg[/IMG]
        [SIZE=1][B]99 Grand Am GT[/B][/SIZE]
        [SIZE=1]3400/3500 -Solid trans mount--TCE 65mm T-body---85mm LS2 maf---1 1/4' TCE intake spacers with 3400 upper--SLP Catback with flowmaster 80--TOG headers
        [URL="http://www.wot-tech.com/shop/cams/rollerregrinds/stock3400sims/3400%20with%20Ported%203500%20Top%20End/1357.pdf"]1357[/URL] cam 227 233 .050 dur[/SIZE][SIZE=1] 515 515 lift 112 lsa
        15.232@88.85mph on stock 3400---New time to come[/SIZE]
        [URL="http://www.motortopia.com/garage/cars/95blackz26"]
        [/URL]
          is that enough for a 3500 or should i upgrade them?
            should be, assuming you don't go absolutely nuts with it. stock, fine
              are the 2000 + injectors better quality? the one i had from a 99 were big and ugly, i got a new rail and injectors from an 01 ga the other day and they look completely different.
                they are different, but better quality? i don't know about that, they're newer, and designed for higher pressure, if that means anything for you. i believe they use different connectors for electrical as well...
                  im staying stock for now, im turboing next summer, but i was planing on a new set of injectors when that time comes.
