Alright, so I've been tinkering with this 99 GAGT for a long time on and off since I first bought it. This thing doesn't have all the power it suppose to. I've tried everything. Today I put the scanner on it and went to a test that was igntion mode. It said that if it said yes beside it while running that it was in ignition mode. According to the scanner, igntion mode is on when there is a fault in the igntion system. When that happens, it uses the ICM to control ignition timing instead of the ECM. It also said that the ICM will maintain base timing at 10 degrees BTDC and affect driveability noticeably. Does that sound like something that would make the car sluggish?? I don't know much about ignition timing. Also, what kind of ignition fault could I have? The ICM is new and not that it matters, all the coils, plugs and wires are also new. BTW, I have no fault codes so diagnosing this igntion fault is gonna be tricky. Anyone have any ideas? Thanks in advance.
EDIT: Also, I read that the wiring from the crank sensor to the ICM has to have a minimum of 9 turns per foot. WHY? How do I know of my crank sensor needs replaced? I HATE THIS CAR!!
