To do this, I need the megasquirt to understand the LX9 crank reluctor. I knew the megasquirt supports the LS1 crank reluctor which looks a lot like the LX9 reluctor, but it was my understanding that the LX9 reluctor is 58x whereas the LS1 is 24x. Well today I plotted the LX9 reluctor and then plotted the LS1 reluctor. I used 'A' for long and 'B' for short, and 0 for the forward wheel (in the pictures) and 1 for further. These are my results.
LS1 = A1B0 B1A0 B1A0 B1A0 B1A0 B1A0 A1B0 B1A0 B1A0 B1A0 A1B0 A1B0 B1A0 B1A0 A1B0 A1B0 A1B0 B1A0 A1B0 B1A0 A1B0 A1B0 A1B0 A1B0
LX9 = A1B0 B1A0 B1A0 B1A0 B1A0 B1A0 A1B0 B1A0 B1A0 B1A0 A1B0 A1B0 B1A0 B1A0 A1B0 A1B0 A1B0 B1A0 A1B0 B1A0 A1B0 A1B0 A1B0 A1B0
EDIT: I have rearranged the order so that it matches what the CPS sees. I basically mirrored and reversed the previous. I also started in a different location to match the LS1 configuration for TDC #1 compression.
They are the same.
So my next step is to determine where the wheel is at TDC of cyl 1. Brad, I used your picture of the crank reluctor when I plotted. I noticed you marked the reluctor. Did you mark that TDC cyl1?
Is there anyone who has a LX9 crank laying around that they can determine TDC cyl1 for me?
