Hello,
after hours of searching, I've only found a little information on the v6 that was set aside 5 years ago for my dad's jeep. recently, my dad has decided to sell the jeep and I'm buying it.
He got a motor from another jeep guy in the area that was supposed to be a great motor for the jeep. it's a 60 degree GM v6, but I can't find much more than that.
It has a distributor on it, and either a 2 barrel carburetor or TBI setup... I'm not sure how to tell the difference between them.
The engine mounts are evenly spaced front to back and the bellhousing is still attached. the bellhousing looks to be the same as the mounting pattern that connects to the chevy rwd and 4x4 transmissions, so I'm pretty sure it's F body or S-10/15.
On the Driver's side, it has 889 LH6 cast into it, and on the passenger side GM 1407888. I can't find any displacement casting. It has individual belts, not a serpentine.
As far as i can tell, the serpentine was implemented in all v6's after 1987. is this correct? If so, does that mean I have a 2.8l?
Thanks in advance for the help!
Dan
Dan
