I'm having issues.... I'm trying to finish my 3.4 swap into my jimmy today, and the water pump off my 85 2.8 is rubbing on the timing cover on my 3.4.
The timing cover I'm using is from the 3.4 crate engine, and all the bolt holes and coolant passages line up, so I'm confident it's the correct rotation for the v-belt setup.
The water pump shaft appears to be too long for this timing cover, as only the little hub on the end of the shaft is rubbing.
I believe i'm using the correct gasket, however, the old 2.8 timing cover shows some signs of contact, but definatly could be spun by hand with no belt on.
The water pump is also a GM part, according to the impeller blade.
Any suggestions?
Any suggestions?
