I got a motor back from the machine shop and they changed out the freeze plugs and unfortunately tossed the old ones including the rear cam plug.
SO what are you guys using as a replacement? GM doesn't list anything on Parts direct and the number of the part on a exploded view on Nalley GMC isn't identified either.
This motor is using an aftermarket cam so I believe I do not need the bump in the plug as OEM has since the back of the cam will be flat and not have the hollow core protruding through the last journal.
The bearing OD size as noted on the Clevite catalog is around 2.0090/2.0110... So I need a plug that size for the rear of the engine, any suggestions?
I have a 3500 and 3100 block here but I would rather not steal those unless that's my last resort.
And a 3100 too but I don't want to pull that engine apart, it's my "numbers matching" engine to the pink car... LOL like that would ever matter.
