I think I still have one of those adapters if you want it.
Is the 2.8l really what I want?
Originally posted by caffeine View PostIf your 2.8 is a pre-88 engine, you'll most likely need an 88+ flywheel (neutral balance). You'll know if the old flywheel is 88+ or not because the old flywheels have an obvious weight cast in to the engine side.
So this is usable? It would be nice if SOME parts from the old 2.8L could be reused.
Yeah if you bring the flywheel somewhere that balances stuff they can neutral balance it which is no different than just buying a new neutral balanced one... Just quite possibly way cheaper.
Anyone who does that shouldn't be working on a car... LOLOriginally posted by neophile_17 View PostOK I wasn't as clear as I should've been. If the balance was verified to be neutral I would run it. Simply milling or grinding off the pads and hoping for the best is not a path I would take even if it's worked for others.
lol, spend a week in the Fiero community...Originally posted by 3400-95-Modified View PostAnyone who does that shouldn't be working on a car... LOL"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
And here's a dual pocket bellhousing that's had the external slave mount removed and the T5 front bearing retainer modified to use a 96+ T5 HTOB.
Is there a slicker bellhousing that could be used, or should I just pick up one of those dual-pockets & shave off the external mount, as Caffeine did.
What about this Camaro bellhousing? http://www.ebay.com/itm/380901977849...%3AMEBIDX%3AIT
Originally posted by 3400-95-Modified View PostYeah if you bring the flywheel somewhere that balances stuff they can neutral balance it which is no different than just buying a new neutral balanced one... Just quite possibly way cheaper.
So what do you think about this? It has no wear on the teeth, just the rust issues and that cast weight. I can throw the thing in the glassbead cabinet and clean up this side
