Tonight I sat in a drive thru for 1/2 hour and the motor got pretty hot (fans kicked on at 227). After that I noticed my oil pressure seemed lower than usual (maybe it was lower before I didn't notice). It only showed 3 "bars" on my digital gauge at idle, and didn't rise up as much as normal when I stepped on it. I recently did an oil change with the PF52 filter, semi-synthetic 5w30 oil, and a dose of Restore.
What could be causing the lower pressure reading? The fact that the motor got hot for a time? Could using restore cause a drop in pressure? Maybe tomorrow the pressure will be back up to normal....hopefully.
What do you guys think?
