ya so im having a wierd problem here. first off can anyone tell me what the 3 wires of a 95 style alt. do. i know 1 is rewquired to have switched power so that the alt. will charge when powered. the other 2 im not sure of i looked at another car (91 cutlass with the same style plug) and there is a thick red with 2 thin (1 thin being the switched power). the other 2 have constant power to them at all times. now i only hooked up the switched power on my car. This was with a BN alternator. i ran it that night and then shortly after my alt is no longer charging and my car is dead. SO i am wondering maybe the other 2 (thick and other thin) are required to give power to the alternator to regulate the voltage maybe??? because after installing this new alt. it only lasted about 3 h before it cooked and is no longer able to charge.
Someone please help.. if you could at least tell me what the other 2 wires on that 3 pin plug do that would be greatly appreciated. i think maybe they must be connected to avoid kiling the alt? also noticed the alt. humming sound right after hooking the BRAND NEW ac delco alt. up.
THanks
CHris
THanks
CHris
