Like the tilte says just wondering how to check the timing on my car. It's a '89 GP with a 2.8.
How can you check your timing???
I don't know the damn thing has been running like crap for awhile now. It's mainly at idle it runs real rough and sometimes stalls and then other times after it has warmed up and been shut off it wont restart for 30 mins to a hour then runs fine again. I have put in a new crank sensor, new wires, plugs, air filter, the cat doesn't make any noise, pcv valve is new, no vaccuum leaks, battery is brand new (two days old) , O2 senor, all plug wires have spark, altenator tested fine, idle relearn. Now i'm kinda outta ideas, sometimes I can get it going after it stalls but it runs like it is only off a few cyilnders or something and has no power and when the gas is let off it dies right away. The problem is intermittent and happens at all temps, gas levels, and times of day or night, wet or dry. The only other thing I can tell you is that sometimes the exaust smells like gas a bit and at idle with the brakes on and right before it stalls the voltige meter is very very low (almost in the red). So I was thinking maybe my timing is off but then it would happen more offten right??? Sorry this is so long
Long is good. Details are good.
IAC sounds like it could be it. Also sounds like your ECM might be corrupted, but that seems to happen very rarely in GM's. You have changed the fuel filter too, right?
\"I think I\'ll take this oppurtunity to remove my ears.\"
--Capt. Jean-Luc Picard
94 Grand Am GT 3100 16.4@83mph
WAI, custom exhaust, MSD Coils
yes fuel filter has been done and I have cleaned the IAC but it was pretty filthy, maybe i'll try one of those couldn't hurt right. Also my speedo is off by 15 kph. I don't know if that is related but there it is. Thanx for the tips guys. I appreciate it.
That would be a problem with your wheel speed sensor, if an 89 would have WSS and not a cable. But if you DO have a WSS I guess it could have something to do with some of the other problems, except idle.\"I think I\'ll take this oppurtunity to remove my ears.\"
sounds liek a bad ECM. If your speed is off, but you have not changed anything with the transmission, or the ECM, then sounds like your ECM, or the MEM-CAL is taking a crap. I would try getting a new ECM and and chip, and see if that fixes the problem.Taylor
1998 Lincoln Mark VIII
Shorted fuel injector. I'm almost willing to bet on it. I've been down this road 3 times with my car. Most of the other suggestions would set the SES light on. . Should be 12 ohms. Any lower and they draw too much current from the ECM which can cause a stumble. REAL low and the car will die completely. Let it cool off and it will run for a while.
A way to check without pulling the plenum is to disconnect the ECM. Find the injector wires (usually pink & blue) and measure there. They are wired in parallell banks of three. With all 3 connected, you should read around 4 ohms on each bank. any lower, and you're pulling the plenum to read them individually.
Hope this helps!90 Chev Lumina 3.1 398 000 KMs
If if works, DON\'T FIX IT.
The memcal is a chip on the ECM board.
From what I understand you need a new ECM (the whole computer board). Should be able to use any ECM from 88-93(? before the 3100?) and put your exsisting Memcal prom chip on the new ECM. Someone correct me if I'm wrong.
